Sapim Race Straight-Pull Spoke
$1.35
Article number: Spokes
Sapim Race Straight-Pull spokes are a durable, double-butted stainless steel option designed for reliable performance across a wide range of wheel builds. Featuring a 2.0 - 1.8 - 2.0mm profile, they offer improved fatigue resistance and weight savings compared to straight gauge spokes while maintaining excellent strength.
Built for modern straight-pull hub systems, Sapim Race delivers a balance of durability, consistency, and value for road, gravel, and mountain applications.
  • Double-butted 2.0 - 1.8 - 2.0mm stainless steel construction
  • Improved fatigue resistance over straight gauge spokes
  • Balanced strength-to-weight ratio
  • Straight-pull design for modern hub compatibility
  • Reliable, cost-effective spoke for high-mileage use
Sapim Race Straight-Pull is ideal for riders who prioritize durability and long-term reliability over weight or aerodynamic performance.
Best suited for training wheels, gravel builds, mountain bike wheels, and high-mileage road setups.
For aerodynamic performance and lower weight, choose Sapim CX-Ray. For increased stiffness and strength in high-load builds, choose Sapim CX-Sprint.
Wheelbuilding Notes
Double-butted spokes provide greater elasticity than straight gauge spokes, allowing them to better absorb load and maintain tension over time. This improves long-term durability and reduces fatigue-related failures.
Need help calculating spoke length? Use the Spoke Length Calculator, or contact our wheel builders.
Weight ~6.0 g
Material Stainless Steel
Profile 2.0 - 1.8 - 2.0 mm
Head Type Straight-Pull
Custom Spoke Cutting Available
We can cut Sapim Race straight-pull spokes to order when stock is available within 20 mm of the required length.
For exact lengths or custom builds, contact our wheel builders.
