$12.00
Article number: 001-05-01
SRAM Carbon Crank Arm Guards help protect SRAM carbon crank arms from pedal strikes, trail debris, and everyday wear. These lightweight injection-molded boots fit over the crank ends to reduce cosmetic damage while preserving the structure and appearance of high-end carbon cranksets.
Designed for SRAM carbon crank arms such as XX1 Eagle, X01 Eagle, and Descendant Carbon models, the guards provide simple protection without affecting pedaling performance or crank clearance.
Why Use SRAM Carbon Crank Arm Guards
Carbon crank arms are vulnerable to pedal strikes and rock impacts, particularly on mountain and gravel terrain. Crank arm guards provide a simple way to protect exposed crank ends while maintaining the original appearance and value of the component.
  • Protects SRAM carbon crank arms from impacts and abrasion
  • Compatible with SRAM XX1 Eagle, X01 Eagle, and Descendant Carbon cranks
  • Helps prevent scratches, chips, and cosmetic wear
  • Precision molded for clean installation
  • Allows pedal and hex tool access without removal
 Specification SRAM Carbon Crank Boots
 Material Injection Molded Plastic
 Weight ~15 g
 Includes One Pair Of Crank Arm Guards
A simple protection upgrade for riders looking to preserve SRAM carbon crank arms during trail riding and everyday use.
