SRAM Centerline XR Disc Brake Rotor
| Article number: | 001-04-01 |
SRAM Centerline XR (X Road) Rotors are designed for road, gravel, and endurance braking systems where weight, aerodynamics, and consistent braking performance matter. The two-piece construction combines a stainless steel braking surface with an aluminum spider to improve heat management while reducing system weight.
Optimized for SRAM AXS road drivetrains and modern disc brake setups, Centerline XR rotors deliver smooth, quiet braking with stable thermal performance during extended descents and high-load braking situations.
Why Use SRAM Centerline XR Rotors
Road and gravel braking systems benefit from rotors that balance weight reduction with thermal stability. The Centerline XR rotor uses a two-piece carrier to improve heat management while maintaining consistent braking feel across long descents and mixed terrain riding.
- Two-piece rotor construction with aluminum carrier
- Stainless steel braking surface for durability
- Centerline braking track designed for quiet operation
- Rounded edges for easier wheel installation
- Suitable for road, gravel, and endurance applications
Note: 140 mm Centerlock rotors do not include a lockring.
