Abbey Bike Tools Bottom Bracket Socket Tool
| Article number: | 005-05-01 |
Abbey Bike Tools took the road less traveled when crafting their bottom bracket socket tools. Rather than casting or forging, these sockets are precision CNC machined in the USA from solid billets of 7075 aluminum for unrivaled accuracy and longevity. The finger splines allow you to hand start installation without marring new parts.
Offered in dual and single sided configurations to fit all major bottom bracket types, Abbey's sockets are visually striking and a pleasure to use. When your bike demands the best tools, reach for Abbey Bike Tools' bottom bracket socket set, proudly made in Portland, Oregon.
Check out the Shimano Crank Pre Load Tool for removal or adjusting the preload cap
DUAL SIDED:
Dura-Ace / Ultegra
Compatible only with Shimano Dura-Ace 9000 (and newer), Ultegra 6800 (and newer), 105 5800 (and newer), and current XTR bottom bracket shell types. These shells are somewhat smaller than the traditional external bottom bracket cups that you may be accustomed to, so be sure to check which drivetrain you’re running before purchasing.
SINGLE SIDED:
Hollowtech II
This tool is compatible with all outboard bearing cups that the dual sided tool doesn't fit, Campagnolo, SRAM, FSA and older Shimano.
THM
Compatible with all THM bottom brackets, except the new internal T47.
BSA30 12 Notch
This is the new version of the popular dual sided socket tool; used for SRAM DUB, Race Face Cinch, Rotor BSA 30, and Zipp Vuma Quad bottom brackets. This is not compatible with Praxis, TorqTite, or Hope. (46 mm x 24 notch)
BSA30 16 Notch
This is the new version of the popular dual sided socket tool; used with FSA 386-EVO cups and some Wheels Mfg cups. This is not compatible with TorqTite, Praxis or Hope. (44 mm x 16 notch)
Praxis
Compatible with the Praxis M30, M30 Thru and Conversion bottom bracket, except the new internal T47.
TorqTite
Compatible with the TorqTite BSA30 bottom bracket.
Colnago
Compatible with Colnago's 30mm bottom bracket.
Chris King
Compatible with Chris King's Thread Fit 30 & 47 bottom brackets.
| Material | Aluminum |
| Compatibility | All sockets are 3/8” square driver compatible |
