Abbey Bike Tools Shop Tools
$105.00
Article number: 005-05-03
Abbey Bike Tools Saw Guide and Lever Setter are precision workshop tools designed to simplify two common setup tasks: cutting fork steerers and setting brake or shift lever position. Each tool solves a specific alignment problem in modern bike assembly, helping mechanics work more accurately during cockpit setup and front-end service.
The Saw Guide is designed for controlled steerer cutting, including setups with internal cable routing, while the Lever Setter works with the Abbey Bike Tools H.A.G. to help establish consistent lever position across different handlebar shapes.
Why Use Abbey Saw Guide
The Saw Guide is designed to improve fork steerer cutting accuracy, especially on bikes with cables routed through the steerer. Its U-shaped design allows the guide to slide around the tube rather than over it, making it easier to position on built bikes or partially assembled front ends.
  • Designed for cutting fork steerers with improved blade guidance
  • U-shaped design allows installation around the steerer instead of over it
  • Useful for internally routed steerers where top access is limited
  • Can also be secured in a vise for controlled shop use
  • Dual-sided design supports both toothed metal blades and abrasive composite blades
Why Use Abbey Lever Setter
The Lever Setter is designed to help mechanics set brake and shift lever position more consistently across different road and mountain handlebar shapes. Used with the Abbey H.A.G., it provides a repeatable reference point that helps compensate for varying bar bends during cockpit setup.
  • Helps set brake and shift levers more consistently
  • Designed to work with the Abbey H.A.G.
  • Compensates for variation in road and mountain handlebar bends
  • Threads into compatible star nuts or expansion plugs
  • Useful during bike assembly, fit changes, and cockpit service
 Saw Guide
 Use Fork Steerer Cutting Guide
 Blade Support Toothed Metal Blades / Abrasive Composite Blades
 Compatibility 1 in and 1-1/8 in Fork Steerers; Not Compatible with 1-1/4 in
 Lever Setter
 Use Brake and Shift Lever Positioning Tool
 Compatibility Requires Star Nut or Compression Plug with M6 x 1 Thread
 Recommended Setup Use a Headset Spacer Between Stem and Setter for a Stable Base
Pairs Well With
The Lever Setter is designed to be used with the Abbey Bike Tools H.A.G. for consistent lever setup. The Saw Guide fits well into workshop toolkits focused on fork preparation, cockpit assembly, and front-end service.
