Ashima Centerlock Rotor
| Article number: | 007-05-04 |
The Ashima Centerlock Rotor pairs a SUS410 stainless-steel braking ring with your choice of 7075-T6 alloy or stainless-steel carrier (size-dependent). The two-piece construction improves heat stability and rotor trueness, while the Centerlock interface speeds installation and alignment. Available in 140, 160, and 180 mm with verified weights below. Materials and construction match Ashima’s lightweight performance focus seen across Ai2/AiNeon families.
Use cases:
- road, gravel, CX; choose alloy carrier for lower mass
- steel carrier for maximum robustness.
| 140 mm | 160 mm | 180 mm | |
| Weight | |||
| Alloy Carrier | ~96g | ~122g | |
| Steel Carrier | ~133g | ~161g | |
| Material | |||
| SUS410 Stainless Steel Rotor | |||
| 7075-T6 Aluminum Carrier | |||
| Stainless Steel Carrier | |||
- Need hardware? Add our Ashima Rotor Bolt Set (Aluminum or Steel) for 6-bolt builds,
- or Centerlock lockring for your hub.
- Comparing weights? See KCNC Nordit Disc Rotor or Carbon-Ti Centerlock X-Rotor for ultra-light alternatives.
| _____________________: | _________________________ |
| Material: | • Aluminum Carrier / Stainless Carrier / SUS Steel Rotor |
| Compatibility: | • Centerlock |
| Rotor Thickness: | • 1.8 mm |
| Includes: | • Rotor and :ockring |
