AeroLite Carbon Pedals
| Article number: | 011-03-05 |
The Aerolite Carbon Pedal system delivers an ultra-minimalist approach to clipless design, relying on a cylindrical pedal body and a 304° Wraparound Cleat Interface for secure engagement. Once clipped in, the system can withstand over 1300 lb of upward force, yet disengages naturally through ankle supination for a secure, intuitive release.
Proudly engineered and manufactured in the USA, Aerolite pedals utilize titanium spindles, Turcite bushings, and DuPont Zytel ST Nylon cleats for strength-to-weight efficiency. The Road and TT versions reduce weight further with optimized titanium spindles (ceramic-coated in the TT edition) and refined internals.
The Road series accommodates both 3-bolt road shoes and 2-bolt mountain shoes, while the Time Trial models use a shortened spindle for a narrower Q-Factor and improved aerodynamic efficiency.
Note: Pedals are supplied with Road cleats. MTB cleats are available separately.
Highlights
- 304° Cleat Wrap For Secure Engagement
- Over 1300 lb Upward Retention Under Load
- Natural Release Through Ankle Supination
- Road Version Supports 3-Bolt Road + 2-Bolt MTB Shoes
- TT Version Uses Shortened Spindle For Narrower Q-Factor
- Made In The USA
| Road | TT | Titanium | |
| Weight (Pair) | ~71.5 g | ~65.5 g | ~62 g |
| Cleats & Hardware | ~47 g | ||
| Material | |||
| Spindle | Aluminum | ||
| Bearing | Carbon-Wrapped Turcite Bearing | ||
| Cleat | DuPont Zytel ST Nylon | ||
