$440.00
Article number: 008-05-01
As an offshoot of exotic materials manufacturer, LLS Titanium, Carbon-Ti draws from many years of material science experience in order to create components of the highest quality.
Uniquely machined from 7075 T-6 aluminum, the Straight Pull X-Hub is both lightweight and resilient. Equipped with an ingenious toolless bearing preload adjuster, the X-Hub can be perfectly dialed in on the fly, and ensures that any adjustments stay where you want them. By simply turning the knurled endcap, any bearing micro adjustment is possible within seconds. Easy to overhaul and built to last, the X-Hub additionally utilizes the tried-and-true 4 pawl freehub body design featuring a quick-engaging 56 tooth ratchet ring, giving each rider the peace of mind knowing their components won’t fail in the middle of a long ride
WHEEL BUILDING
Trust a skilled wheelbuilder for your Carbon-Ti built wheels. Contact us for custom wheels, we offer expert service and rim / spoke advice.
 Weight ~189g
 Spoke Holes 24h
 Axle Standard 12 x 142 mm
 Bearing Size 6903 - (1) / 6803 - (1)
 Brake Interface Centerlock
--Wheel Building Dimensions--
  LEFT RIGHT
 Flange Diameter  48 mm 54.5 mm
 Center to Flange 36 mm 18 mm
 Spoke Hole Offset 2.0 mm
 Spoke Hole Diameter 2.5 mm
