DT Swiss 240 EXP Boost J-Bend Disc Front Hub
The venerated 240s hub has seen various design changes through the years, but has stayed true to its original concept of simplicity and durability. Keeping up with the ever changing industry, DT Swiss has tweaked their hubs exemplary design to mate perfectly with the new wider Boost forks and frames. With the same dependability and serviceability as previous generations, Boost hubs boast increased stiffness which helps in handling. Keeping the front wheel tracking straight under extreme riding conditions allows riders to rail corners and roll over rock gardens with more confidence. With the popularity of 29” wheels and the introduction of plus-size bikes, increased lateral stiffness becomes essential for longer travel, aggressive trail bikes. However, riders of every discipline can gain advantage from more responsive steering and handling. With standard-sized sealed cartridge bearings and j-bend spoke flanges these hubs offer easy service and parts replacement by most shops and home mechanics with basic tools. The optimal hub for riders who demand the most of their equipment, DT 240 EXP hubs will keep you rolling all day and all season long.
Covered by a 2 year warranty against manufacturing and material defects, 240 EXP hubs offer some of the best performance in the industry.
Wheel Building
We recommend that wheels with DT Swiss hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us or submit a form for a custom wheel build.
Centerlock | 6-Bolt | |
Weight | ~120 grams | ~143 grams |
Bearing Size | 1728 (2) | |
Spoke Holes | 28 / 32 | |
Axle Standard | 15 x 110mm Boost | |
--Wheelbuilding Dimensions-- | ||
Flange Diameter Left | 44.4 mm | 57.8 mm |
Flange Diameter Right | 44.4 mm | 49.4 mm |
Center to Left Flange | 27.6 mm | 27.3 mm |
Center to Right Flange | 41.2 mm | 41 mm |
Spoke Hole Diameter | 2.55 mm |
