$27.20
Article number: 024-02-02
The DT Swiss centerlock adapter allows ISO 6-bolt rotors to be quickly and easily fitted to the splines on a centerlock brake rotor mount. With the lockring's external tool splines, the internal diameter of the adapter is increased, allowing for use on hubs with all common axle standards: quick release, 12mm, 15mm, and 20mm. These high quality adapters are manufactured in Switzerland by DT Swiss.
Compatibility
 Fits Road - Max 160mm Rotor
MTB - Max 210mm Rotor
 Weight Road - ~31 grams
MTB - ~42 grams
 Hub Type Centerlock
 Max Rotor Size 210 mm
 Rotor Thickness 1.8 - 2.2 mm
