DT Swiss Centerlock Adapter
Article number: | 010-03-05 |
The DT Swiss centerlock adapter allows ISO 6-bolt rotors to be quickly and easily fitted to the splines on a centerlock brake rotor mount. With the lockring's external tool splines, the internal diameter of the adapter is increased, allowing for use on hubs with all common axle standards: quick release, 12mm, 15mm, and 20mm. These high quality adapters are manufactured in Switzerland by DT Swiss.
Compatibility | |
Fits | Road - Max 160mm Rotor MTB - Max 210mm Rotor |
Weight | Road - ~31 grams MTB - ~42 grams |
Hub Type | Centerlock |
Max Rotor Size | 210 mm |
Rotor Thickness | 1.8 - 2.2 mm |
