DT Swiss Centerlock Adapter
Article number: | 010-03-05 |
The DT Swiss Centerlock Adapter allows ISO 6-bolt rotors to be quickly and easily fitted to the splines on a centerlock brake rotor mount. With the lockring's external tool splines, the internal diameter of the adapter is increased, allowing for use on hubs with all common axle standards: quick release, 12mm, 15mm, and 20mm. These high quality adapters are manufactured in Switzerland by DT Swiss.
Compatibility | Road | MTB |
Fits | Max 160 mm | Max 210 mm |
Weight | ~31g | ~42g |
Hub Type | Centerlock | |
Max Rotor Size | 210 mm | |
Rotor Thickness | ~1.8 - 2.2 mm |
