$600.00
Article number: ENVE-Rims
ENVE Foundation AM30 Disc Rim is a carbon mountain rim built for aggressive trail and all-mountain riding. Its 30mm internal width, 20mm depth, 3mm offset spoke bed, and hookless tubeless profile are designed to support modern 2.3" to 2.6" tires with a stable shape and controlled ride feel.
Handmade in Ogden, Utah, the AM30 is aimed at riders who want a durable carbon rim for custom wheel builds that prioritize traction, impact control, and predictable handling over ultra-light XC-focused design.
Why Use The ENVE Foundation AM30 Rim
The AM30 is designed for riders building a modern trail or all-mountain wheelset around wider tires, lower pressures, and a stronger rim platform suited to rougher terrain.
  • 30mm internal width supports modern 2.3" to 2.6" mountain tires
  • Hookless tubeless bead profile is intended for lower-pressure off-road use
  • 3mm offset drilling helps balance spoke tension in custom builds
  • 20mm rim depth keeps the profile compact and trail-oriented
  • Available in both 29" and 27.5" sizes with 28-hole drilling
 Specification 29" 27.5"
 Intended Use Trail / All-Mountain
 Wheel Size 29" 27.5"
 Rim Depth 20 mm
 Internal Width 30 mm
 External Width 39 mm
 Approximate Weight ~510g ~470g
 Recommended Tire Size 2.3" - 2.6"
 ERD 605 mm 564 mm
 Rim Offset 3 mm
 Hole Count 28 Hole
 Bead Type Hookless
 Tire Type Tubeless Ready
 Valve Stem Length 35 mm
 Tubeless Tape Width 43.5 mm
Included
AM30 Tubeless Kit
Brass Nipples
Build Notes
The AM30 should be positioned as a custom-build rim for trail and all-mountain use, not as an XC race rim. The 30mm internal width and 2.3" to 2.6" tire range make it best suited to builds focused on traction, support, and impact management on rough terrain.
For complete custom wheel planning, use our Custom Wheels service or contact us for hub and spoke recommendations.
Related Options
Need tubeless setup parts? Add the ENVE PRV Tubeless Valve Stem Kit.
Building a full wheelset from the ground up? Start with our Custom Wheels page.
