ENVE Combo Computer Mount
$75.00
Article number: ENVE-2-2
Manufactured in the USA by K-Edge, ENVE has teamed up to introduce the newest iteration of their sleek, integrated stem mount, the Aero Adjustable Mount. These mounts, manufactured from 6061 T6 aluminum, use a co-polymer insert to minimize wear on the computer's mounting tabs, and is replaceable to allow compatibility with Garmin, Wahoo and Sigma computers. With each ENVE Computer mounts all mounting hardware, inserts for Garmin computers, Wahoo computers, and an underside Go-Pro style mount for action cameras or lights are included (the underside insert can also be removed altogether).
Aero Adjustable
This combination computer/accessory mount is designed for use with ENVE Aero Road Stems and features up to 25 degrees of adjustability. This mount uses a single bolt to attach to the Aero Stem's faceplate in a fixed slot to keep it rigid and secure. As with all K-Edge computer mounts, this uses a co-polymer insert to minimize wear on the computer's mounting tabs, and is replaceable to allow compatibility with Wahoo and Sigma computers.
Aero
This mount uses a single bolt to attach to the Aero Stem's faceplate in a fixed slot to keep it rigid and secure. Integrated mounts such as these improve the aerodynamics of the bicycle's front end while eliminating the clutter of accessory mounts from the handlebars. As with all K-Edge computer mounts, this uses a co-polymer insert to minimize wear on the computer's mounting tabs, and is replaceable to allow compatibility with Wahoo and Sigma computers.
2-Bolt
ENVE’s Road Stem Computer Mount doubles the functionality of the original with an underside mount for action cameras or lights. These mounts, manufactured from 6061 T6 aluminum, feature interchangeable inserts that allow usage with a multitude of computers, cameras, and lights. This mount installs only onto the ENVE road stems using the included longer stem bolts providing a seamless aesthetic by blending perfectly with the contours of the stem’s faceplate. Finished handsomely in black, each mount weighs 60 grams (including hardware) and features small, subtle ENVE and K-Edge logos in white.
 Weight Aero Adjustable 2-Bolt
 Combo ~42g ~50g ~60g
 Mount ~28.5g ~35g ~37g
 Stem Compatibility Aero Stem Road Stem
 Computer Compatibility Garmin / Wahoo
 Lower Mount Compatibility Go-Pro style cameras and lights
 All Mounts Include
  1 - Garmin / 1 - Wahoo Mount
  1 - Removable Camera / Light Mount
2-Bolt Includes 2 - 30 mm Replacement Bolts
Aero & Adj. Includes 1 Mounting Bolt
