ENVE Foundation AM30 Wheelset
ENVE Foundation AM30 Wheelset is a carbon mountain wheelset built for trail and all-mountain riding. The AM30 uses a 30mm internal rim profile, hookless bead design, and a 3mm offset spoke bed to support modern high-volume tires while maintaining balanced spoke tension and long-term wheel durability.
The wheelset’s ride-tuned carbon construction is designed to manage vibration and impact forces across rough terrain while maintaining responsive handling. Available in both 27.5" and 29" sizes, with Boost and SuperBoost compatibility, the AM30 is intended for riders who want a durable carbon wheelset for aggressive trail riding.
Why Use The ENVE AM30 Wheelset
The AM30 wheelset is designed for riders who want a stable carbon wheel platform built around modern trail tire widths and lower pressures while maintaining durability for long-term use.
- 30mm internal rim width supports modern 2.3" to 2.6" trail tires
- Hookless bead design helps reduce pinch-flat risk and improve tire stability
- 3mm rim offset improves spoke tension balance and wheel durability
- Carbon layup tuned for vibration control and trail compliance
- Available in 27.5" and 29" sizes with Boost and SuperBoost configurations
Build Notes
The AM30 wheelset is positioned for trail and all-mountain riding rather than XC racing. Its 30mm internal width supports wider trail tires while the offset spoke design helps balance spoke tension and improve long-term wheel durability.
For custom builds using the same AM30 rims, visit our Custom Wheels service or contact us for hub and spoke recommendations.
