Fair Wheel Bikes Tubeless Tape
$14.00
Article number: 013-03-02
Fair Wheel Bikes Tubeless Tape is a high-adhesion rim sealing tape designed for tubeless 700c and 29-inch wheelsets. Available in multiple widths from 19 mm to 34 mm, it covers a wide range of modern road, gravel, and mountain rim profiles.
Each roll is 10 meters long, enough to apply a single layer to four 700c / 29-inch rims. The adhesive backing is designed to resist tearing, sealant exposure, and heat, helping create a clean, reliable tubeless setup with strong rim-bed adhesion.
Specification
Intended Use Tubeless rim sealing tape
Wheel Size 700c / 29-inch rims
Available Widths 19 mm – 34 mm
Roll Length 10 meters
Coverage Approximately four 700c / 29-inch rims with a single layer
Construction Flexible, tear-resistant tape with adhesive backing
Why Proper Tape Width Matters
Tubeless tape should cover the rim bed cleanly without riding too far up the sidewall. Choosing the correct width helps seal spoke holes, reduce air loss, and improve tubeless tire setup consistency.
Installation Tips
Step Recommendation
Clean Rim Bed Remove old tape, adhesive residue, dirt, and sealant before installation.
Center Tape Apply the tape evenly through the rim bed and keep light tension to prevent wrinkles.
Overlap Overlap the tape by approximately 5–10 mm at the valve area.
Press Firmly Press the tape into the rim bed with a roller, tire lever, or flat tool to improve adhesion.
Final Check After adding sealant, inspect the wheel after the first ride for seepage or air loss.
