Far and Near Shox Cap
$5.00
Far and Near Shox Valve Caps provide essential protection for suspension forks and rear shocks, helping keep air valves clean and functioning properly. Machined from 6061 aluminum and finished in anodized colors, these caps combine durability with a clean, refined look.
Each cap includes a rubber o-ring for improved grip and secure installation, making removal and reinstallation easier while maintaining a tight seal. Designed for Schrader valves, they help prevent dirt, moisture, and debris from contaminating your suspension system.
  • Suspension forks and rear shocks using Schrader valves
  • Protecting air valves from dirt, dust, and moisture
  • Replacing worn or missing OEM valve caps
  • Adding a subtle anodized detail to custom builds
  • Riders maintaining long-term suspension performance
 Weight ~2 g (Each)
 Valve Compatibility Schrader
 Material 6061 Aluminum
 Seal Rubber O-Ring
 Sold As Individual
Keeping valves protected is a small but important step in maintaining consistent suspension performance and long-term reliability.
