Far And Near Titanium Rotor Bolts
| Article number: | 28-04-05 |
Enhance your bike's performance with Far and Near's Titanium Rotor Bolt Set. This package contains 12 lightweight bolts, perfect for securing a pair of standard 6-bolt rotors. By replacing traditional stainless steel bolts with these titanium ones, you can achieve an impressive 15-gram weight reduction.
INSTALLATION
For optimal results and to ensure your disc spins true, it's advisable to use a torque wrench to tighten the bolts in a star pattern. Always follow the torque specifications recommended by the disc manufacturer. These bolts are equipped with a T25 torx bit for easy installation.
| Bolt Thread | M5 x 10 mm |
| Weight | ~11g (per Wheel) |
| Material | 6/4 Titanium |
