KCNC O/S Centerlock Adapter
$26.00
Article number: 022-05-02
These centerlock adapters from KCNC are designed to allow the use of standard ISO 6-bolt rotors with centerlock hubs. Since Shimano is the only manufacturer of centerlock rotors, adapters such as these make possible the use of more widely available rotors, as well as exotic and lightweight options.
This adapter comes as an oversize version, we stock this version as it is the most versatile. The adapter can be used on any hub from a Quick Release to a 20mm Thru Axle.
Start by positioning the rotor between the adapter's splined inner plate and the outer pegged plate. Next, attach the assembled rotor and adapter to the hub. Once it's aligned with the hub's centerlock mount, thread on the lockring and tighten it using an ISIS/Octalink BB Tool. If you have a torque wrench, tighten the lockring to 40 Nm.
 Weight ~28g
 Material 6061 Aluminum
 Tools Required ISIS/Octalink Style BB Tool
 Recommended Torque 40Nm
