$494.95
Article number: 015
The Praxis Doon road crankset, with its C.R.A.F.T. (Carbon Resin Automated Filament Technology) carbon process, offers a perfect blend of lightness (342g for 172.5mm) and stiffness for peak power transfer. Compatible with 10-12 speed drivetrains across major brands, it features an M30-THRU spindle for broad compatibility. Available with 2Tone LevaTime II chainrings or as crankarm-only, it ensures precise shifting with a 147mm Q-factor and 44.5mm chainline. The Doon is a testament to Praxis' engineering excellence.
 Crankarms 165 mm 170 mm 172.5 mm 175 mm
 Weight ~337g ~339g ~342g ~345g
 Chainrings 48t / 32t 50t / 34t 52t / 36t
 Weight ~195g ~202g ~211g
 Q-Factor 147 mm
 Chainline (*) 2x - 44.5 mm / 1x - 45.5 mm
 Drivetrain (*) 2x / Double 1x / Single
 Chainring Options 48t / 32t - 50t / 34t - 52t / 36t Any SRAM Style DM
 Bottom Bracket Praxis M30 Thru
 Chain Compatibility 10 / 11 / 12 - Shimano, KMC, Campagnolo, SRAM (Flattop Included)
 Spindle M30 Thru - 30mm Spindle (Drive / Non-Drive Side)
 Material Carbon Arms, Aluminum Spider & Chainrings
 Interface/BCD SRAM (Praxis) 3-Bolt Style / 160 BCD
(*)2x - Not Compatible with GRX Front Derailleurs
