Praxis M30 Bottom Bracket
| Article number: | 015-04-04 |
The Praxis M30 bottom bracket provides a solid platform for the Zayante crankset. Its stepped 30 to 28mm spindle perfectly matches the crank's design for optimal power transfer and efficiency. Praxis' innovative "wide stance" technology pushes the cartridge bearings outward, moving your feet's pedaling forces further from the frame. This creates rock-solid pedaling stability while avoiding problematic frame tolerances. Currently available for most major bottom bracket standards, the M30 bottom bracket delivers Praxis' signature quiet performance and long service life through thoughtful engineering. Riders trust Praxis for bottom brackets engineered for their cranksets.
Praxis M30 threaded bottom brackets require the M30 BB Tool to be correctly installed. The T47 Internal requires the T47 I.B tool, while any press-fit versions should be installed using a good quality bearing press. The T47 Asym uses both. Compatibility is listed below.
| BB Compatibility | ||
| Fitment | Weight | Bracket Width |
| BSA 68 / 73 (English Thread) | ~100g | 68 / 73 mm |
| BB86 / 90 / 92 | ~65g | 86.5 / 89.5 / 92 / 104.5 / 107 |
| BB30 / PF30 - 68 / 73 mm | ~100g / ~130g | 68 / 73 mm |
| BB386 EVO | ~104g | 86.5 mm |
| BBRight | ~130g | 79 mm |
| T47 Asymmetric | ~100g | Road - 76.75 mm / MTB - 81.25 mm |
| T47 Internal | ~100g | 85.5 mm |
| T47 External | ~100g | 68 / 73 mm |
| Crank Compatibility | ||
| Praxis / Box BMX / Oval / *InfoCrank | ||
| Bearings | ||
| 30 mm Drive / 28 mm Non-Drive | ||
| 6806 / Propriety - Cartridge Steel or Ceramic | ||
| Tools / Installation | ||
| T47 Asym and T47 Internal use the T47 Tool | ||
| BSA, BB30 / PF30, and T47 Asym use a M30 socket tool or wrench | ||
| All others use a quality bearing press | ||
| *InfoCrank not compatible w/BB386 EVO | ||
