Praxis Wave 1X Direct Mount Road/Gravel/CX Chainring
$85.00
$68.00
* Unit price: $68.00 /
Article number: 28-05-01
Availability: In stock (2)
The new Wave format for Praxis Works single chainrings is akin to the Narrow-Wide style rings that have taken the industry by storm in recent years. Wave however offers some significant advantages that should be noted. Using alternating lateral force on each chain link Wave chainrings actively retain the chain, while still allowing space to shed accumulated mud and debris. There is also less friction when compared to traditional narrow wide rings when run at less than optimal chain lines. For riders running a single speed system this is of little concern, but with ever increasing drivetrain gear counts and the introduction of wider tires, chains and chainrings are being pushed to their limits.
Please select your chainring according to your crank and frame style. If you have questions please contact us and we will assist you in selecting the optimal ring for your needs.
All Direct Mount Road / Gravel / CX chainrings are Not Compatible with Campagnolo 11 / 12 / 13 Speed chains.
Chainline
45.5 mm | 48 mm (Gravel Cranks)
Material
CNC Machined 7075-T6 Aluminum Hard Blk Anodized
Recommended Rear Derailleur
Clutch Type Derailleur Shim. Shadow Plus or SRAM Type 2 or Upper Chain Guide
Crank Compatibility
Praxis Direct Mount crank or SRAM 3-Bolt Direct Mount style
Chain Compatibility
10 / 11 / 12 Speed - Shimano, SRAM, KMC
Drivetrain Compatibility
10 / 11 / 12 spd Shimano / SRAM mechanical and electronic
Weights
36t ~92g 38t ~96g 40t ~99g
42t ~112g 44t ~151g 46t ~155g
48t ~166g 50t ~171g
