Schmolke TLO Carbon Seatpost
$525.00
Article number: 011-05-02
The Schmolke TLO Carbon Seatpost is handmade in Germany from high-modulus carbon fiber for the perfect balance of comfort and performance. Designed with tuned vertical compliance, it filters road vibration without sacrificing lateral or torsional stiffness, ensuring maximum efficiency and control.
Weighing as little as ~79g, the TLO is among the lightest seatposts available. A sleek, minimalist form enhances any build, while compatibility with 7 x 7, 7 x 9, and 7 x 10 mm saddle rails and an internal Di2 battery mount add modern functionality. Titanium hardware provides secure clamping with long-term durability.
Engineered for dedicated road use, the TLO Carbon Seatpost sets a benchmark for ultralight performance, reliability, and craftsmanship.
 Length 280 mm 300 mm 350 mm
 Approx. Weight
27.2 mm ~79g ~83g ~90g
31.6 mm ~82g ~86g ~95g
 Intended Use Road Only
 Saddle Rails 7 x 7 / 7 x 9 / 7 x 10 mm
 Torque (Saddle Rails) 5Nm
 Maximum Rider Weight 220 lbs (100 kg.)
Insertion Range (Seat Rails to Seat Collar)
  150 - 200 mm 160 - 220 mm 195 - 265 mm
Pair the Schmolke TLO Seatpost:
