Schmolke Roadbar EVO TLO Handlebar
$699.00
Article number: 011-05-04
The Schmolke Roadbar EVO TLO is the pinnacle of ergonomic, ultralight cockpit design. Its involute drop curve provides an aerodynamic yet natural hand position, balancing performance with long-ride comfort. The nearly horizontal transition between the drops and brake hoods minimizes wrist strain, while the flattened tops offer an anatomically secure grip for extended climbing or cruising.
To maintain rigidity without excess bulk, the bar’s tops retain a subtle curvature that preserves structural integrity. Recessed cable grooves ensure straightforward external routing, while integrated porting expands options for internal cable routing (ICR). Three dedicated openings—one on each side at hood height and one centered at the back—allow seamless compatibility with modern fully integrated setups.
Handmade in Germany from high-modulus carbon, the TLO bar combines minimal weight with uncompromising strength, making it one of the lightest and most technically advanced drop bars available.
 Measured *(O - O) 40cm 42cm 44cm
 Weight ~145g ~147g ~151g
 Reach 73 mm 78 mm
 Drop 125 mm 126 mm
 Stem Clamp Diameter 31.8 mm
 Material Carbon Fiber
 Finish 1K Weave or UD Matte
 ICR Compatible Yes (internal ports)
 Rider Weight Limit 243 lbs (110 kg)
 Torque Faceplate / Shift / Brake Clamp - 3-3.5Nm
*Outside to Outside
