Risk Titanium Brake Bolt Kit RT124
$75.00
Article number: 017-05-01
The Risk Titanium Brake Bolt Kit (RT124) is a comprehensive titanium hardware upgrade set for Shimano hydraulic disc brake systems, replacing key steel fasteners used on brake calipers and levers. Designed for XT and SLX families sharing common architecture, this kit reduces weight while improving corrosion resistance in high-exposure environments.
The kit includes titanium replacements for critical brake mounting and service bolts, making it suitable for full brake refreshes, wet-climate bikes, or performance builds where long-term durability and serviceability are priorities. All bolts are precision-machined from titanium alloy and intended as direct replacements for OEM hardware.
This is brake hardware only — no pistons, seals, hoses, or calipers included.
Installation Note:
— This kit contains multiple brake fasteners. Always verify each bolt’s function and location during installation and torque according to brake manufacturer specifications.
Includes Tool Torque
1) Oil Reservoir Cover Bolts - RT062 5 mm* 2Nm
2) Oil Compression Screws - RT115 8 mm** 7Nm
3) Caliper Exhaust Screw - RT114 7 mm** 6Nm
4) Brake Lever Travel Adj. Screws 3 mm* -
5) Brake Lever Clamp Screws - RT028 4 mm* 8Nm
6) Caliper Fixing Screws - RT038 5 mm* 12Nm
7) Oil Tank Fixing Screws - RT119 4 mm* 12Nm
8) Pentagonal Screws - RT116 4 mm* 10Nm
9) Brake Pad Pins - RT118 3 mm* 4Nm
10) Brake Pad Retaining Rings - RT118 - -
*Hex Wrench
**Socket Wrench
