Risk Titanium Hydraulic Brake Caliper Bolt / Washer RT038
$17.00
Article number: 017-05-01
The Risk Titanium Hydraulic Brake Caliper Bolt & Washer (RT-038) is a lightweight replacement fastener set for securing hydraulic disc brake calipers to frames or forks. Machined from corrosion-resistant titanium alloy, these bolts replace standard steel caliper hardware to reduce weight while maintaining proper clamping force under braking loads.
RT-038 is designed around the standard M6 disc brake caliper mounting interface used by many Shimano systems. Supplied with matching washers, it ensures even load distribution and clean caliper alignment when installed to manufacturer torque specifications.
 Fits M6
 Length 18 mm
 Weight ~13g
 Includes 4 - M6 Bolts & Washers
