Risk Titanium Oil Compression Screw RT115
$12.00
Article number: 017-05-01
The Risk Titanium Hydraulic Brake Oil Compression Screw (RT115) is a precision replacement fastener for securing hydraulic brake hoses using olive and insert fittings. Machined from corrosion-resistant titanium alloy, it replaces the OEM steel compression screw to improve durability and resistance to corrosion caused by brake fluid exposure.
RT115 is designed for hydraulic disc brake systems that use a threaded compression screwto seal the hose connection. Ideal for brake hose replacement, caliper swaps, or refreshing corroded service hardware in wet or high-use conditions.
Installation Note:
Use with the correct olive and hose insert for your brake system. Always torque to manufacturer specifications to ensure a leak-free hydraulic seal.
 Weight ~3g
 Tools 8 mm Socket Wrench
 Includes 2 Screws
 Dimension M8 x 0.75 x 9 mm
 Material Titanium
For a brake upgrade kit, check out the RT124.
For other upgrade parts, check out these cockpit or brake parts.
