Risk Titanium Hydraulic Integrated Reservoir Cover Bolt RT062
| Article number: | 017-05-01 |
The Risk Titanium Hydraulic Oil Reservoir Cover Bolt (RT062) is a precision replacement screw for securing the oil reservoir cover on select Shimano hydraulic brake levers. Machined from corrosion-resistant titanium alloy, it replaces the OEM steel fastener to reduce weight while maintaining a secure seal during brake bleeding and service.
RT062 is designed for earlier Shimano hydraulic brake lever generations, where reservoir cover depth and thread engagement differ from later XT/XTR designs. Correct bolt length is critical to avoid lever damage or fluid leakage.
Compatibility Note: Confirm lever model before purchase.
RT062 is not interchangeable with RT063.
| Weight | ~1.3g |
| Material | Titanium |
| Includes | 2 - Small Bolt |
| Dimension | M5 x 5 mm x 8.5 mm |
