Risk Titanium Hydraulic Reservoir Bolts RT063
| Article number: | 017-05-01 |
The Risk Titanium Hydraulic Oil Reservoir Cover Bolt (RT063) is a precision replacement fastener for oil reservoir covers on later-generation Shimano XT and XTR hydraulic brake levers, including M7000, M8000, and M9000 series designs.
Manufactured from titanium alloy, RT063 improves corrosion resistance and long-term durability while maintaining proper thread engagement and sealing depth required for modern Shimano brake levers.
Not sure which bolt you need?
Shimano hydraulic brake levers use different reservoir cover screw lengths depending on generation.
• XT / XTR M7000, M8000, M9000, M9020 → RT062
• Older M615, M675, M785 → RT063
| Weight | ~2.2 |
| Material | Titanium |
| Includes | 2 - Large Bolt / 2 - Small Bolt |
| Dimension | Lg Bolt - M5 x 5 mm x 10 mm Sm Bolt - M3 x 5.2 mm x 5.2 mm |
