Risk Titanium Hydraulic Brake Pad Pins RT118
| Article number: | 017-05-01 |
The Risk Titanium Hydraulic Brake Pad Retention Pin (RT118) is a lightweight replacement for the threaded pin used to secure disc brake pads inside hydraulic calipers. Machined from corrosion-resistant titanium alloy, it replaces OEM steel pad pins to improve durability and resistance to corrosion caused by heat, moisture, and repeated service.
RT118 is designed for Shimano-style hydraulic disc brake calipers that use a threaded pad retention pin, making it ideal for routine brake pad replacement, wet-climate riding, or refreshing corroded hardware.
Installation Note:
Always torque to manufacturer specifications and ensure proper pad seating before riding. Use thread treatment only if specified by the brake manufacturer.
| Weight | ~2.5g |
| Tools | 3 mm Hex Wrench |
| Includes | 2 Screws |
| Dimension | M4 x 25 mm |
| Material | Titanium |
For a brake upgrade kit, check out the RT124.
For other upgrade parts, check out these cockpit or brake parts.
