Risk Titanium Hydraulic Caliper Exhaust Screw RT114
| Article number: | 017-05-01 |
The Risk Titanium Hydraulic Disc Brake Caliper Bleed Screw (RT114) is a precision replacement for the bleed screw used on hydraulic disc brake calipers. Machined from corrosion-resistant titanium alloy, it replaces the OEM steel screw to improve durability and long-term resistance to corrosion caused by brake fluid exposure and repeated service.
RT114 is designed for calipers that use a standard M6 bleed screw, commonly found on Shimano hydraulic disc brake systems. Ideal for routine brake service, wet-climate riding, or replacing damaged or corroded bleed screws.
Installation Note:
Always reuse or replace the correct sealing washer or O-ring as specified by the brake manufacturer. Torque lightly to manufacturer specifications—over-tightening may damage caliper threads.
| Weight | ~3.5g |
| Tools | 7 mm Open Ended Wrench |
| Includes | 2 Screws |
| Dimension | M6 x 20.6 mm |
| Material | Titanium |
For a full brake upgrade check out the RT124
