SRAM RED Flattop 12 / 13 Speed Chain
| Article number: | 001-04-02 |
| Delivery time: | 3-5 days |
SRAM RED Flattop Chain is designed for SRAM’s 12-speed road drivetrains using the distinctive Flattop chain profile. The narrower shape increases strength while allowing tighter drivetrain spacing for modern AXS systems.
Hard chrome-plated inner plates and rollers improve wear resistance, while HollowPin construction and machined outer plates reduce weight without compromising durability. The chain is supplied with a Flattop PowerLock for installation and service.
Waxed Chain Option
Our optional chain waxing service prepares the chain using a multi-step process that removes factory grease and replaces it with a high-performance wax coating. Waxed chains run quieter, stay cleaner, and typically require less frequent drivetrain cleaning.
- Degreased and fully cleaned before waxing
- Hot-wax treated using Molten Speed Wax
- Wax cured and inspected before packaging
- Quieter drivetrain operation with reduced contamination
- Ideal for riders maintaining waxed drivetrain systems
Because the waxing process takes several days, riders often keep a second pre-waxed chain ready for rotation.
Related SRAM Road Drivetrain Products And Waxing Resources
Pair this chain with compatible drivetrain components and maintenance products for a cleaner and more consistent road setup.
- Chain waxing service details
- Molten Speed Wax for rewaxing and maintenance
- Road cassette options for drivetrain refreshes
- Chainring options for compatible crank setups
