$1,349.00
* Unit price: $1,349.00 /
Article number: 30-05-02
The THM Frontale is a fully integrated carbon handlebar(Ulna) and stem(Tibia) combo engineered for aerodynamic superiority, ultra-light weight, and stiffness. Whether you're racing crits, climbing mountains, or shaving seconds in a time trial, the Frontale offers precise control and optimized positioning.
Designed with structural efficiency and reduced frontal area in mind, the original Frontale remains a favorite among performance-focused cyclists. For riders seeking even more aerodynamic refinement, we now also offer the THM Frontale Aero version, which features sleeker shaping and improved airflow management — ideal for time trials, triathlons, or flat-out speed setups.
INSTALLATION & ORDERING
The Ulna handlebar is not compatible with aero extensions, use of which will void the warranty. THM measures their handlebar widths at the drops, please keep this in mind when ordering.
 Handlebar 40cm 42cm 44cm
 C to C Hoods 38 cm 40 cm 42 cm
 C to C Drops 40 cm 42 cm 44 cm
 Reach 77 mm
 Drop 119 mm
 Flare
 Stem 90 mm 100 mm 110 mm
 Angle -6°
 Stack Height 40 mm
 Stem Clamp Diameter 31.8 mm
 Material Carbon Fiber
 Finish Matte
 Rider Weight Limit 243 lbs (110 kg)
