Wahoo Speedplay PowrLink
| Article number: | 011-04-02 |
Wahoo POWRLINK ZERO Power Meter Pedals combine Speedplay’s dual-sided road pedal platform with integrated power measurement for riders who want precise training data without moving away from Speedplay cleats. Available in single-sided and dual-sided versions, POWRLINK ZERO provides power, cadence, rechargeable battery operation, ANT+ / Bluetooth connectivity, and the adjustable float that makes the Speedplay system popular for road fit refinement.
Single-Sided vs Dual-Sided Power
The single-sided version measures from the left pedal and estimates total power, making it the lighter-cost entry point into pedal-based power. The dual-sided version measures both pedals independently, adding left/right balance data for riders who want more detailed analysis of pedaling symmetry, fit changes, fatigue, or rehabilitation-related differences.
Why Choose POWRLINK ZERO
- Pedal-based power: easy to move between compatible road bikes.
- Speedplay platform: low stack height, dual-sided entry, aerodynamic cleat profile, and adjustable float.
- Training data: power, cadence, battery status, and wireless head unit compatibility.
- Rechargeable battery: up to 75 hours of ride time per charge.
- Road-focused design: intended for road use with Speedplay cleats.
Fit and Compatibility Notes
POWRLINK ZERO uses the Speedplay cleat system and is designed for road riding. The 13mm stack height and 55mm Q factor should be considered when switching from standard Speedplay pedals or another road pedal system, especially for riders with a dialed-in saddle height or cleat position.
