Woodman Capsule Extrem
Article number: | 016-06-02 |
Woodman Components' Capsule Extrem is an innovative, simple-to-use headset preload assembly built for more aggressive riding styles where headset security is paramount. The Capsule Extrem eschews the traditional steerer plug in favor of a more robust sandwich design for headset adjustment and steerer tube reinforcement. Intended for suspension forks, but compatible with any open-bottom steerer tubes, this preload assembly features an adjustable length with clearly marked graduations for quick and easy sizing. The Casule Extreme will accommodate total steerer tube lengths from 175-270 mm. As an added bonus, the Capsule's underside is equipped with female M5 thread as an option for mounting a front fender.
The Capsule Extrem is available in two diameters; one for traditional 1-1/8" steerer tubes, and another for oversize 1-1/2" steerer tubes. It is possible to combine the upper and lower halves of each size to accommodate the most common size 1-1/8" to 1-1/2" tapered steerer tube.
Weight, 1-1/8" | 75 grams |
Weight, 1-1/2" | 133 grams |
Material | 6061 T6 aluminum |
Adjustment Range | 175-270 mm |
