Woodman EL Seatpost
$159.00
Article number: 012-02-04
Woodman EL Seatpost is a lightweight alloy seatpost built for riders who want dependable clamp security, low weight, and a neutral fit position without moving to carbon. Its scalloped T6-aluminum tube, machined cradle hardware, and titanium fasteners trim excess mass while preserving the durability expected from a high-quality alloy post.
The zero-offset head works well for riders who prefer a more centered saddle position, and the clamp supports both metal and carbon rails in 7 x 7 / 7 x 9 / 7 x 10 mm formats. That makes the EL a strong option for road, gravel, and light XC builds where fit, saddle compatibility, and long-term reliability matter more than chasing exotic materials.
Important: Do not cut the seatpost. The clamping load is engineered around the original unmodified post length.
 Diameter 27.2 mm 31.6 mm
 Length 350 mm 400 mm 350 mm 400 mm
 Weight ~144 g ~196 g ~178 g ~209 g
 Min. Insertion 85 mm 95 mm 85 mm 95 mm
 Max. Insertion 210 mm 235 mm 210 mm 235 mm
 Offset 0 mm
 Rail Compatibility 7 x 7 / 7 x 9 / 7 x 10 mm
 Material T6 Aluminum
Looking for a similar zero-offset fit in a lighter carbon format? The Woodman Carbo EL Seatpost offers a comparable inline fit with carbon construction and premium titanium bolts.
For riders comparing premium inline carbon options, the MCFK Carbon Straight Seatpost is another strong choice for lightweight road-focused builds.
Complete the setup with a lightweight collar such as the Woodman Deathgrip TCSL Seatpost Collar or the Carbon-Ti X-Clamp Seatpost Collar.
