Woodman IT Zero Setback Integrated Seat Mast 34.9mm
Article number: | 03-02-04 |
Each Woodman IT series ISP head begins life as a single billet of aluminum, and is precision machined into the completed product. Equipped with high grade titanium hardware, the Woodman IT is among the lightest options available.
Precision-machined from 6061 T6 aluminum and equipped with high grade titanium hardware, the Woodman IT seatmast is among the lightest options available.
The IT features a cradle-and-yoke design that is compatible with metal or carbon rails in either round or ovalized design. The forward yoke bolt requires a 5.5 mm box end wrench, which is included along with installation instructions.
Weight | ~89 grams |
Material | 6061 T6 aluminum |
Hardware | machined titanium |
Max Torque | 5 Nm |
Rail Compatibility | round, ovalized |
ISP interface diameter | 34.9 mm |
Height Adjustment Range | 10 mm |
Setback | 0 mm |
