Abbey Bike Tools T-handle Tool
$60.00
Article number: 005-05-02
The Abbey Bike Tools T-handle multi-tool is a great addition to any shop at home or at work. This is purpose built to be a more robust multi use tool than their 4-way Multi Tool using the same durable stainless steel as the Crombie. Using precision stainless steel bits from WERA that fit like a glove into the bolts on your modern bike; they won't strip out fasteners like other tools that are common in the bike world.
Everybody makes a multi-tool, there is a bit of everything on the market, but the difference is in the details.
Choose between two pre‑configured bit sets (4 / 5 mm + T‑25 or 5 / 6 mm + T‑25), or a full 10‑bit magnetic set** (2–6 mm hex | Torx 10/15/20/25/30 | #2 JIS Phillips). When configured with magnets, it also acts as a swappable-bit tool for bench use or travel.
 INCLUDED HEX TORX
 4 / 5 / T-25 4 mm / 5 mm T-25
 5 / 6 / T-25 5 mm / 6 mm T-25
 10 Piece Bit Set 2 / 2.5 / 3 / 4 / 5 / 6 15 / 20 / 25 / 30
 Material  Chassis  Bits
  Stainless Steel WERA Stainless Steel
