Alpitude Stelvio Out Front Carbon Computer Mount
| Article number: | 016-01-01 |
The Stelvio Out-Front Computer Mount features a lightweight, semi-universal design to fit a wide range of stems and cycle computers. At ~18g, these are among the lightest computer mounts available. The interchangeable and replaceable quarter-turn base is manufactured from high-strength plastic to reduce friction and abrasion on the computer's mounting tabs. This computer interface is attached to the lightweight carbon arm of the Stelvio through two of four threaded brass inserts, depending on the particular mount type. The machined aluminum base is slotted for 1.4cm of left-right adjustability, and connects to the stem using a single titanium bolt and aluminum standoff spacer. The Stelvio is available in short and normal arm lengths to fit either Garmin or Wahoo computers.
The Stelvio is compatible with most stems that use M5 bolts with forward-facing bolt heads. The normal length mount is designed for larger devices such as the Garmin 1030 and 1000, while the short version is compatible with all smaller devices under 85 mm in length. Please contact us if you have questions regarding compatibility.
| Short | Normal | |
| Weight | ~15g | ~21g |
| Length, Short | 79 mm | 89 mm |
| Stem Compatibility | M5 Bolts (22-36mm apart for proper centering) | |
