Craig's Tool
| Article number: | 003-01-01 |
Craig’s Tool is a compact, lightweight multi-tool designed for riders who want only the essentials. Built around a traditional L-handle format, it delivers the leverage and control of a full-size hex key in a portable system suited for on-road use.
The modular design uses double-ended bits secured magnetically in the handle, with a fiber-reinforced nylon bit caddy clipped directly to the tool. This allows quick bit changes without loose parts, while keeping everything organized and easy to access during roadside adjustments.
Constructed from high-strength aluminum with 440C heat-treated stainless steel bits, the system balances durability with low weight. An optional titanium plug tool expands functionality for tubeless repairs without adding bulk.
- L-handle design for improved leverage and control
- Double-ended bits with magnetic retention
- Integrated nylon bit caddy for organized storage
- Compact system designed for road use
- Optional titanium plug tool for tubeless repairs
- Lightweight construction for minimal carry weight
