DT Swiss 180 EXP Straight-Pull Disc Front Hub
| Article number: | 023-06-02 |
The latest 180 hub generation enhances DT Swiss' top-of-the-line hub. Ratchet EXP system boosts bearing lifetime, stiffness by 15%, and energy transfer with 36 teeth. Tool-free disassembly and lightweight design make maintenance a breeze. Paired with SINC ceramic bearings, these hubs offer unparalleled performance.
WHEEL BUILDING
| Compare | |||
| 24 hole | 28 hole | 240 | |
| Weight | ~92g | ~98g | ~105g |
| Axle Standard | 12 x 100 mm | 12 x 100 mm | |
| Bearing Size | Ceramic 6802 - (2) | 1526 - (2) | |
| Brake Interface | Centerlock | Centerlock | |
| --Wheel Building Dimensions-- | ||
| 24 hole | 28 hole | |
| Flange Diameter Left | 35.7 mm | 35.2 mm |
| Flange Diameter Right | 35.1 mm | 34.6 mm |
| Center to Left Flange | 21.8 mm | 21.5 mm |
| Center to Right Flange | 35.1 mm | 34.7 mm |
| Spoke Hole Offset L / R | 1.5 mm / 1.75 mm | 2.1 mm / 1.9 mm |
| Spoke Hole Diameter | 2.5 mm | |
