$685.00
$600.00
* Unit price: $599.38 /
Article number: ENVE-Rims
ENVE Foundation Rims bring ENVE’s molded spoke-hole construction, hookless tubeless profiles, and modern rim shaping into a more accessible custom-build range. This Foundation series includes two road-focused rim options, the 45 and 65, plus two gravel-specific options, the AG25 and AG28.
The Foundation 45 and 65 are intended for modern road builds using 25mm to 28mm tires, while the AG25 and AG28 are designed around higher-volume gravel tires and mixed-surface riding. Together, the Foundation range gives riders a clear path to road or gravel custom wheels using ENVE’s tubeless-ready carbon rim platform.
Why Use ENVE Foundation Rims
The Foundation rim range is designed for riders who want ENVE’s molded carbon rim construction and tubeless-ready hookless design in a family of rims that covers both road and gravel custom wheel builds.
  • Foundation 45 and 65 cover modern road rim depths for all-around or deeper aero builds
  • AG25 and AG28 cover gravel applications with wider internal rim profiles
  • Molded spoke holes improve durability and serviceability
  • Hookless tubeless-ready construction supports modern tire shapes and pressures
  • Each model includes rim-specific tubeless kit compatibility for complete setup
 Specification 45 65 AG25 AG28
 Intended Use Road Gravel
 Wheel Size 700c 700c 650b
 Rim Depth 45 mm 65 mm 21 mm
 Internal Width 21 mm 25 mm 28 mm
 External Width 28 mm 33.5 mm 36.5 mm
 Approximate Weight ~455g ~510g ~360g ~372g
 Recommended Tire Width 25 mm - 28 mm 36 mm - 50 mm 47 mm - 57 mm
 Min. Compatible Tire Width 700 x 25 700 x 32 650b x 45
 ERD 568 mm 528 mm 597 mm 564 mm
 Valve Stem Length 59 mm 80 mm 35 mm 35 mm
 Tubeless Tape Width 25 mm 25 mm 29 mm 30.5 mm
 Hole Count 24 Hole
 Bead Type Hookless
 Tire Type Tubeless Ready
Included
 Tubeless Kit 45 Kit 65 Kit AG25 Kit AG28 Kit
Brass Nipples
Build Notes
For complete custom wheel planning, start with our Custom Wheels service or contact us for hub and spoke recommendations.
Related Options
Need setup parts? Add the appropriate ENVE Gravel / Road Tubeless Kit, ENVE PRV Tubeless Valve Stem Kit. Planning a complete build? Visit our Custom Wheels page.
