ENVE SES 3.4 Carbon Clincher Tubeless Rim
$2,190.00
Article number: ENVE-Rims
ENVE SES 3.4 Carbon Clincher Tubeless Rim is a modern all-road and climbing-focused disc rim that balances low weight, aerodynamic benefit, and higher-volume tire support. With 39mm front and 43mm rear depths, a 25mm internal width, and ENVE’s hookless tubeless construction, it is built for fast riding across a wide range of terrain.
The SES 3.4 works particularly well for riders who want a responsive custom wheel build for road racing, mountainous routes, rough pavement, and mixed-surface road events using larger modern road tires.
Why Use The ENVE SES 3.4 Rim
The SES 3.4 is one of the most broadly useful ENVE road rim options, offering lower weight than deeper aero models while keeping the wider tubeless platform many riders now prefer for control, comfort, and speed on imperfect roads.
  • 39mm front and 43mm rear depths for balanced climbing and all-around speed
  • 25mm internal width supports modern road tire volume
  • Hookless tubeless bead design for accurate tubeless setup
  • Well suited to technical descents, rough pavement, and varied terrain
  • Strong fit for lightweight road and all-road custom builds
 Specification
 Intended Use Lightweight Road / All-Road Rim Builds
 Wheel Size 700c
 Front Rim Depth 39mm
 Rear Rim Depth 43mm
 External Width 32mm
 Internal Width 25mm
 ERD 578 Front / 591 Rear
 Approximate Weight ~370g Front / ~378g Rear
 Hole Count 24 Hole
 Bead Type Hookless
 Tire Type Tubeless Ready
 Minimum Tire Size 700 x 27
 Valve Stem Length 59mm Front / 61mm Rear
 Tubeless Tape Width 29mm
 Included Tubeless Kit (SES 3.4 (AR)), Brass Nipples, Valve Extenders (55 mm)
Build Notes
The SES 3.4 is one of the easiest rims in this group to position as a lightweight all-around road build. It carries less depth than the 4.5 and 6.7 while keeping a wide modern tubeless platform that suits rough pavement and varied terrain.
Related Options
For a lower-profile climbing-focused option, see the ENVE SES 2.3 Carbon Clincher Tubeless Rim.
For more aerodynamic depth, compare the ENVE SES 4.5 Carbon Clincher Tubeless Rim.
