Carbon-Ti X-Hub SP Centerlock Front Disc Hub
$254.95
Article number: 008-06-05
The Straight-Pull Centerlock Front Hub from Carbon-Ti is unquestionably an excellent example of their design and machining prowess. Featuring an ingenious tool-free bearing preload adjustment system, the X-Hub can be adjusted to perfection in seconds by simply turning the clever knurled cone. Expertly machined from 7075 T-6 aluminum, the SP X-Hub is both lightweight and robust, two huge necessities for gram conscious riders who often find themselves pushing their components to the limits. Seamlessly paired with the SP X-Hub Rear Disc Hub, each hub from Carbon-Ti is an ideal way to add a dash of exotic Italian flair while simultaneously ensuring the longevity of your next wheelset.
WHEEL BUILDING
Trust a skilled wheelbuilder for your Carbon-Ti built wheels. Contact us for custom wheels, we offer expert service and rim / spoke advice.
 Weight ~92g
 Spoke Holes 24h
 Axle Standard 12 / 15 x 100 mm
 Bearing Size 6803 - (2)
 Brake Interface Centerlock
--Wheel Building Dimensions--
  LEFT RIGHT
 Flange Diameter 48 mm 43.5 mm
 Center to Flange 33 mm 22.5 mm
 Spoke Hole Offset 2.0 mm
 Spoke Hole Diameter 2.5 mm
 Material 7075-T6 Aluminum
For the matching rear version, see the Carbon-Ti X-Hub SP Centerlock Rear Hub
or
Check out the hubset for easier ordering
