ENVE SES 2.3 Carbon Clincher Tubeless Rim
| Article number: | ENVE-Rims |
ENVE SES 2.3 Carbon Clincher Tubeless Rim is ENVE’s shallowest SES road rim option in this group, built for riders prioritizing low weight, climbing response, and predictable road handling. With 28mm front and 32mm rear depths, a 21mm internal width, and hookless tubeless construction, it is aimed squarely at high-performance road disc builds.
This rim is intended for paved-road use and is not the right choice for gravel or off-road applications. For riders building a lighter road wheelset with modern tubeless capability, the SES 2.3 remains a strong option.
Why Use The ENVE SES 2.3 Rim
The SES 2.3 is the most climbing-oriented option in this set, trading some aero depth for lower rim weight and a more responsive feel on steep road rides and elevation-heavy routes.
- 28mm front and 32mm rear depths for low-profile road performance
- Low rim weight for responsive climbing-oriented builds
- 21mm internal width supports modern road tubeless setup
- Hookless bead design for tubeless precision and consistency
- Intended for paved-road use rather than gravel applications
Build Notes
The SES 2.3 should be presented strictly as a rim for paved-road use. It is the lightest and shallowest option in this group, making it the clearest pick for climbing-focused custom wheel builds rather than mixed-surface use.
Related Options
Need more tire volume support and broader all-around use? Compare the ENVE SES 3.4 Carbon Clincher Tubeless Rim.
Looking for wheel build support? Visit our Custom Wheels page.
