Extralite CyberFront SPD-3+ Road Disc Hub
$211.00
* Unit price: $211.00 /
Article number: 010-02-03
Extralite's CyberFront SPD-3 road disc front hub, the third iteration, maintains an ultra-light 66-gram weight. The one-piece hub shell enhances strength, while the cross-laced straight pull design simplifies wheel building and spoke replacement. Improved CNC profiling ensures equalized spoke tension and higher maximum tension. Compatible with standard 14 gauge spokes or Pillar's X-Tra Lite Titanium 13 gauge spokes, it enhances wheel stiffness, reducing lateral flex and improving braking response. Machined from military-grade 7075TX aluminum, each hub features an aesthetic appeal. The micro-tuner allows precise bearing preload adjustment, ensuring minimal friction and zero play. Specifically designed for road disc bikes, it has a rider weight limit of 200 pounds.
Proudly manufactured in Italy, the CyberFront SPD-3 is the optimal choice for constructing an exceptionally lightweight road disc wheel.
SERVICE
Due to the lightweight construction of Extralite hubs, it is recommended that service be performed at frequent intervals to ensure proper function and the longest possible wear life of the internal components. Detailed service instructions can be found here. We recommend Extralite's Alugrease or Buzzy's Slick Honey for proper and effective lubrication of the seals and freehub mechanism.
WHEEL BUILDING
Trust a skilled wheelbuilder for Extralite hubbed wheels. We offer expert service and rim/spoke advice. Contact us for custom wheels.
 Weight ~66g
 Spoke Holes 24h
 Axle Standard 12 x 100 mm
 Bearing Size 6802 - (2)*
 Brake Interface 6-Bolt
*Can be ordered with either XD15 Ceramic, HDC Ceramic, or 440c Stainless Bearings
--Wheel Building Dimensions--
  LEFT RIGHT
 Flange Diameter 30.0 mm 42.0mm
 Center to Flange 33.0 mm 25.0 mm
 Spoke Hole Offset 1.5 mm
 Spoke Hole Diameter 2.8 mm
*for accurate spoke lengths, please use Extralite's Cyber SPD3 hub Lacing Instructions
