KCNC 6061 Rear Thru Axle
$30.00
Article number: 022-02-03
KCNC 6061 Rear Thru Axle is a low-cost, tool-installed replacement rear thru axle for riders who need to replace a lost or damaged stock axle, clean up the rear dropout area, or switch to a lever-free axle design.
Precision-machined from 6061 aluminum, these axles are heavier than KCNC’s 7075 low-profile thru axles, but they offer a more affordable option for everyday replacement use. Installation and removal are handled with a 6 mm hex wrench, with tool fittings on both ends of the axle for easier service access.
Compatibility Note: Rear thru axle fit is frame-specific. Match the axle standard, overall length, thread pitch, thread length, and dropout interface before ordering. Rear hub spacing alone does not confirm axle compatibility.
KCNC 6061 Rear Thru Axle Compatibility
 E-Thru Interface Length Thread Pitch Weight
 167 mm* Flat 167 mm 19 mm 12 x 1.5 mm ~44 g
 172 mm* Flat 172 mm 19 mm 12 x 1.5 mm ~44 g
 177 mm* Flat 177 mm 19 mm 12 x 1.5 mm ~44 g
 Maxle Interface Length Thread Pitch Weight
 180 mm* Flat 180 mm 22 mm 12 x 1.75 mm ~47 g
 188 mm* Flat 188 mm 22 mm 12 x 1.75 mm ~47 g
 Material 6061 Aluminum
 Tool Fitting 6 mm Hex, Both Ends
 Hub Compatibility T/A 12 x 142 | T/A 12 x 148*
 Recommended Torque 10 Nm
For complete sizing details on all of our thru axles, please review our Fair Wheel Bikes thru axle sizing guide or contact us for fitment help.
For a lighter version, compare this axle with the KCNC 7075 Rear Thru Axle. For tool-free installation, see KCNC’s Indexing Rear Thru Axle or QR Rear Thru Axle options.
