KCNC Nordit Centerlock Disc Rotor
$65.00
Article number: 022-03-01
KCNC Nordit Centerlock Disc Rotor is a lightweight two-piece Centerlock brake rotor for road, gravel, cyclocross, and mountain builds using Centerlock hubs. The rotor combines an aluminum carrier with a stainless steel braking track to reduce weight while maintaining a precise braking surface.
Available in 140 mm, 160 mm, and 180 mm sizes, the Nordit uses a 1.8 mm rotor thickness and includes the Centerlock lockring. It is a clean option for riders who want a lighter Centerlock rotor with KCNC’s machined, anodized small-part aesthetic.
Compatibility Note: Designed for Centerlock disc brake hubs. Confirm rotor size, frame/fork clearance, brake caliper requirements, pad compatibility, lockring interface, and hub manufacturer restrictions before ordering.
KCNC Nordit Centerlock Disc Rotor Details
Specification
 Brake Mount Standard Centerlock
 Available Sizes 140 mm, 160 mm, 180 mm
 Rotor Thickness 1.8 mm
 Material Aluminum Carrier / Stainless Steel Braking Track
 Includes Rotor And Centerlock Lockring
Rotor Weights 140 mm 160 mm 180 mm
  ~80 g ~90 g ~107 g
Rotor Size Notes
Choose rotor size based on frame and fork clearance, brake caliper setup, adapter requirements, rider weight, terrain, and braking needs. Road and gravel builds commonly use 140 mm or 160 mm rotors, while 180 mm rotors are generally used when additional braking leverage or heat capacity is needed.
Installation Notes
Install using the included Centerlock lockring and follow the hub or lockring manufacturer’s torque specification. After installation, check rotor clearance, pad alignment, brake pad compound compatibility, caliper centering, and brake function before riding.
Choosing Between KCNC Rotors
Choose the Nordit when your wheels use Centerlock hubs. Choose the Kasditor for a lightweight two-piece 6-bolt rotor, or the Razor for a simpler all-stainless 6-bolt rotor.
For 6-bolt ISO hub setups, compare this Centerlock rotor with the KCNC Kasditor Disc Rotor or the KCNC Razor Disc Rotor. To run compatible 6-bolt rotors on Centerlock hubs, use the KCNC O/S Centerlock Adapter.
