$28.00
Article number: 022-05-01
KCNC Razor Disc Rotor is a lightweight stainless steel 6-bolt disc brake rotor for riders who want a simple, durable, and cost-effective rotor option without moving to a two-piece carrier design.
Precision-machined with double-ground, parallel braking surfaces, the Razor uses a minimalist cutout pattern to reduce weight while keeping the rotor all-stainless. It is available in 140 mm, 160 mm, and 180 mm sizes and includes steel mounting bolts with thread-locking material.
Compatibility Note: Designed for 6-bolt ISO disc brake hubs. Confirm rotor size, frame/fork clearance, brake caliper requirements, pad compatibility, and manufacturer restrictions before ordering.
KCNC Razor Disc Rotor Details
Specification
 Brake Mount Standard 6-Bolt ISO
 Sizes 140 mm, 160 mm, 180 mm
 Rotor Material Stainless Steel
 Braking Surface Double-Ground Parallel Surfaces
 Includes Rotor And Six Steel Mounting Bolts
 Tool Required T25 Torx Wrench
 Recommended Torque 6 Nm
Weights 140 mm 160 mm 180 mm
  ~62 g ~74 g ~95 g
Installation Notes
Install the rotor using the included 6-bolt hardware and a T25 Torx wrench. Tighten the bolts evenly in a star pattern to 6 Nm. After installation, check rotor clearance, caliper alignment, pad contact, and brake function before riding.
Choosing Between KCNC Rotors
Choose the Razor for a simple stainless steel 6-bolt rotor. Choose the Kasditor if you want a lighter two-piece 6-bolt rotor with a 7075 aluminum carrier, or the Nordit if your wheel uses a Centerlock hub interface.
For a lighter two-piece 6-bolt option, compare this with the KCNC Kasditor Disc Rotor. For Centerlock hubs, see the KCNC Nordit Centerlock Disc Rotor or use the KCNC O/S Centerlock Adapter when mounting compatible 6-bolt rotors to Centerlock hubs.
