$82.50
Article number: 015-04-03
Engineered for friction-free spinning and long-term durability, the Praxis Works M24/GXP Bottom Bracket lets you replace worn parts or upgrade existing components with ease. Designed for use with 24mm to 22mm crank spindles, this bottom bracket ensures smooth, quiet pedaling mile after mile. The M24 / GXP uses an older style 16-notch BB Tool for proper installation, while the BB86 fits seamlessly with a quality bearing press. For PF30 / BB30 frames, the conversion bottom bracket includes an adaptor to guarantee compatibility. Compatibility is listed below.
BB Compatibility
Fitment Weight Bracket Width
BSA 68 / 73 (English Thread) ~110g 68 / 73 mm (83 mm DH)
BB86 / 90 / 92 ~80g 86.5 / 89.5 / 92
BB30 / PF30 68 mm ~145g 68 mm
BB30 / PF30 73 mm ~147g 73 mm
Crank Compatibility
Praxis / Oval / SRAM GXP
Bearings
24 mm Drive / 22 mm Non-Drive
2437 / 2237ER - Cartridge Steel or Ceramic
Crank Compatibility
The BB86 / 90 / 92 uses a bearing press; all others use a 44 mm ID socket tool
